Remote Configure
waller.brad
Community Member
I have a 1231 high in a warehouse that needs converted to Autonomous mode.
Please tell me if this will work:
From the controller, revert the ap to a previous release not in LWAPP
Wait for AP to pull DHCP to GUI into, configure from there.
Is that the best way, short of getting a scissor lift to take it down to reconfigure it?
Stephen Rodriguez
That would work well.  Otherwise you would need to get the AP into your hands to be able to convert it to IOS.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
