Aironet 1130AG and 802.1x
Weverton Aranha
Can anyone help me with sources of configuration for 802.1x authentication Aironet 1130AG?
I want to configure 802.1x authentication certificate-based machine (Windows XP and 7), is this possible?
The access-point is operating in standalone mode and the radius server is an ACS 4.2.
Thank you!
Regards, Weverton Aranha
Ok, that is EAP-TLS .. Which BTW is the most involved EAP and requires close attention to detail. You will need a radius server among certificates. I might suggest, you do your home work first before jumping right into configs.
Here is links to get you started:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_white_paper09186a008009256b.shtml
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00807917a6.shtml
__________________________________________________________________________________________
5 Replies 5
George Stefanick
Hi do you mean server side only or client and server side (EAP-TLS)
Hi George,
I need to perform client and server side. The clients will be Win XP/7 and they will authenticate via 802.1x on the Aironet 1130AG.
Thank you for the sources. I will try to do some Labs before startup the production environment.
Feel free to stop back if you have any questions.
