REP on Wireless
gjelke
Frequent Visitor
Frequent Visitor
I have a client needing to have a segment of the REP ring being wireless p2p link. Perhaps even more than one.
I can find documentation of what is supported, is it safe to assume that all other variations are then not supported?
5 Replies 5
pieterh
Supported Platforms
  • Desktop Switching Business Unit (DSBU) Metro Switches (3750ME and ME3400) Release 12.2(40)SE and later
  • Cisco Catalyst 4500 Series Switch Release 12.2(44)SG and later
  • Cisco Catalyst 6500 Series Switch Starting in Whitney2 (12.2SXI)
  • Cisco Catalyst 7600 Series Router Starting in Cobra (12.2SRC)
source: https://www.cisco.com/c/en/us/support/docs/lan-switching/ethernet/116384-technote-rep-00.html
 of course as it is a L2 protocol, it might work over wireless links that transparently forward L2 packets.
but  I would read info in above document as not supported on other devices than above mentioned
added: more supported devices
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/220717-understand-rep-on-catalyst-9000-switches.html
Components Used
The information in this document is based on these software and hardware versions:
  • Catalyst 9200
  • Catalyst 9300
  • Catalyst 9400
  • Catalyst 9500
  • Catalyst 9600
  • Cisco IOS XE 17.6.5 and later
gjelke
Frequent Visitor
Frequent Visitor
Thanks, this is the documents that I had previously found. I was hoping where buried within Cisco's documentation mountain there might have been a tech note or something that suggests that it can be supported in these circumstances.
ammahend
that would be correct, as far as I know Resilient Ethernet Protocol (REP) is not natively designed to run directly over standard Wi-Fi wireless links
-hope this helps-
pieterh
redundancy proticols are there to provide redundancy en improve availability of the network
as such a wireless link is not the best solution (unless Cisco's recently introduced URWB)
but...., if you cannot use a wired link it can still be the best option in this environment
as said before  it probably will work, but i doubt it is documented in any support document by Cisco
and then you want to use multiple wireless segments in the ring.....?.....
-> try to avoid that,
    try to split this in multiple rings each with a single wireless segment
gjelke
Frequent Visitor
Frequent Visitor
Thanks @pieterh , unfortunatly there will be more than one wireless segment due ot the nature of the topology of the physical environment.
