Replicating a Wireless Setup across heterogeneous APs...
ckoeber101
Community Member
Thanks for all of the help provided in previous threads. I am trying now to deploy the setup that works on some APs and doesn't work on others.
For example, on an AIR-AP1231G-A-K9, the following setup works:
version 12.3
no service pad
service password-encryption
hostname AP-6
enable secret 5 $1$TWtQ$NZ9YG6.PSLEfXZK2uoQo91
enable password 7 020C1150020A5A6C1C
username Cisco password 7 072C285F4D06
username admin password 7 0705344747054C4847
ip subnet-zero
ip domain name wesleysem.edu
no aaa new-model
dot11 ssid (Secure) Staff/Faculty
   vlan 70
   authentication open
dot11 ssid Public
   vlan 60
   authentication open
   guest-mode
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 ssid Public
 short-slot-time
 speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
 rts threshold 2312
 power local cck 100
 power local ofdm 30
 channel 2462
 station-role root
 no cdp enable
interface Dot11Radio0.60
 encapsulation dot1Q 60 native
 no ip route-cache
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.70
 encapsulation dot1Q 70
 no ip route-cache
 no cdp enable
 bridge-group 1
interface FastEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address 10.60.255.6 255.255.0.0
 no ip route-cache
ip default-gateway 10.60.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
snmp-server community WesleySNMP RO
snmp-server enable traps tty
bridge 1 route ip
line con 0
 transport preferred all
 transport output all
line vty 0 4
 login local
 transport input all
line vty 5 15
 login
 transport input all
end
But on a AIR-AP1220-IOS-UPGRD (Basically an AP Aironet 1220 with an IOS upgrade), the following setup does not work - neither network connects, even though I tried to make them as similar as possible:
Building configuration...
Current configuration : 2215 bytes
version 12.3
no service pad
hostname AP-7
enable secret 5 $1$S7mv$JLVVGhRBEYTR5D7UXaj3M/
enable password 7 11030C0E1E1E5E4154
ip subnet-zero
no aaa new-model
   vlan 70
   authentication open
   mbssid guest-mode
dot11 ssid Public
   vlan 60
   authentication open
   mbssid guest-mode
dot11 network-map
username Cisco password 7 0501130428401B4449
username admin password 7 020C1150020A5A6C1C
bridge irb
no ip address
no ip route-cache
ssid Public
station-role root
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.60
ip address 10.60.255.7 255.255.0.0
ip helper-address 10.60.0.1
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
ip http server
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
I have both ports connecting to identical port configurations as follows:
interface GigabitEthernet 0/47
switchport trunk native vlan 60
switchport mode trunk
What changes do I need to make to 12.2 IOS and older APs to recognize and use multiple networks?
Thanks.
wjenkins
Level 3
Level 3
You need to assign a different bridge group id to each VLAN on both the radio and ethernet interfaces. You assigned the same IP address to the Fast Ethernet0.60 Interface and the BVI1 interface. You also assigned an IP Helper to the FastEthernmet0.60 Interface and the BVI Interface. Only the BVI1 interface needs an IP address for mangement of the AP. The IP helper should be assigned to the L3 interface on your router or switch to forward the DHCP requests. I would also recommend not using a VLAN for management of the AP that is assigned an SSID especially on the Public/Guest WiFI. It also looks like the 1200 AP is on 12.3 from the listing.
Here is a partial configuration example below for multiple VLANS.
   vlan 70
   authentication open
   mbssid guest-mode
dot11 ssid Public
   vlan 65
   authentication open
   mbssid guest-mode
interface Dot11Radio0.65
encapsulation dot1Q 65
no ip route-cache
bridge-group 65
bridge-group 65 subscriber-loop-control
bridge-group 65 block-unknown-source
no bridge-group 65 source-learning
no bridge-group 65 unicast-flooding
bridge-group 65 spanning-disabled
no ip route-cache
bridge-group 70
bridge-group 70 subscriber-loop-control
bridge-group 70 block-unknown-source
no bridge-group 70 source-learning
no bridge-group 70 unicast-flooding
bridge-group 70 spanning-disabled
no ip route-cache
bridge-group 1
interface FastEthernet0.65
no ip route-cache
bridge-group 65
interface FastEthernet0.70
no ip route-cache
bridge-group 70
interface BVI1
Srin_G
Level 5
Level 5
Chris,
Just like the previous thread, you are trunking to your switchport. I believe there is a L3 switch somewhere to do the routing for vlan 60 and 70.The IP helper can be assigned in the L3 switch for those vlans.
Remove the IP address from BVI1 and shutdown it. Assign the ip address in Fas0.60 in both the AP's. Choose the lease congested channel and it should work fine. We got this setup for all our autonomous system AP's and works without any issues.
