Report for retrieving controller preference
m.glosson
Level 3
Level 3
Is there a method for finding, in a decently readable way (i.e., not "show run-config" or "show access-point-config") a list of all access points' primary, secondary, and tertiary controller preferences? A certain report from WCS, a script, a command from SSH, etc would do. Being able to run it across multiple controllers would be nice too.
Mats Nilson
Level 5
Level 5
Yes, there is.
If you are using WCS there is the Report Launch Pad where you can do this by some editing.
Choose Device --> Inventory --> New
If yoy now choose Report type --> AP and then click on customize you will find more option.
In the Custom Report Name field you change to AP Inventory.
Then choose what data fields you want to use:
Primary Controller
Secondary Controller
Tertiarary Controller
etc, and add to the data fields to include in the report.
You can sort on controllers if needed.
Mats
Mats Nilson
Level 5
Level 5
Yes, there is.
Primary Controller
Mats
