Required a Solution
mansoor_pakistani
Community Member
My network is spread over two remote buildings and the distance between them is nearly 800m.I want to connect the Lan of both building by Aironet 340.Each building have 80 nodes or in future it would be expended.
Now I need a solution and physical network connectivity diagram regarding above scnerio.I have a solution but I have not any idea about the Aironet connectivity on Lan.I mean I need the network diagram that how to connect our Lan to Airnet 340.Since we are using 1800 series cisco switches for nodes connectivity.
Can any one tell me the actual solution for it and network diagram for this solution espetially the Lan connectivity with Aironet 340.
Kindly you can send me email at [email protected] and I am very thankful to you.
ohio_wireless
Community Member
The BR342 is a bridge that connects directly to an ethernet segment, whether on a switch or other ethernet port. One BR342 on each side, and it will make an RF connection between the two ethernet segments. The two segments will become the same segment.
Look at the information you can find at http://wwwin.cisco.com/comlob/eag/aironet/collateral.html page and look for the 340 bridge series information.
Can Br342 support this? because both of the building with 80 users. I though Br342 can support for 8 users only.
kwon47
Community Member
That's the workgroup bridge. the one you want is the Ethernet bridge.
Tony
