Reset AP to factory default enable password not reset
keith.k.quaye
I was trying to  do a password recovery on a 1142 AP  but  enable password did not reset  and I am stuck
AP model is   AIR-AP1142N-A-K9
Running IOS  c1140-k9w7-mx.124-21a.JA1
Its autonomous so there is no controller.  Any direction would be appreciated I renamed the config.txt file  but that did not help  I am unable to rename or delete the  private-config file. I get the message that file or directory cannot be found when i try to rename and permission denied when I try to  delete it.
Do an erase /all nvram:
Scott Fella
Sent from my iPhone
-Scott
12 Replies 12
Scott Fella
Have you tried to hold the mode button down for 15 seconds while powering up the ap?
-Scott
Thanks for your response Scott but I did  that with no luck I just formatted the flash (overkill I think)and  I am tftping  a new image to see if that helps
That will do it too, just didn't want to get you in that situation of having an ap with no image:)
Scott Fella
Sent from my iPhone
-Scott
Funny that didn't seem to work  its not recognizing the default enable which i understand to be cisco.  I am consoled in if that makes any difference.
Scott Fella
Sent from my iPhone
-Scott
Device will not respond to esc or mode button  for me to do that  now. This is weird
What shows up in the console output.
Scott Fella
Sent from my iPhone
-Scott
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x87000800, 0x40000000
RQDC, RFDC : 0x80000037, 0x0000020d
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 143 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 5543936
flashfs[0]: Bytes available: 26841088
flashfs[0]: flashfs fsck took 19 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 64:9e:f3:b3:5c:84
Ethernet speed is 1000 Mb - FULL duplex
Loading "flash:/c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1"...##############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1" uncompressed and installed, entry poi;wçGN¸¸vW7WGçwçÎ99áÃenet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:09 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 143 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32385024
flashfs[1]: Bytes used: 5543936
flashfs[1]: Bytes available: 26841088
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A600 8000 90020000 0 90030000 B
Radio1  present A600 8000 98020000 0 98030000 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1142N-A-K9     (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1547E8D8
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from watchdog timer expired
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 64:9E:F3:B3:5C:84
Part Number                          : 73-12836-03
PCA Assembly Number                  : 800-33767-03
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15441UUL
Top Assembly Part Number             : 800-33775-02
Top Assembly Serial Number           : FTX1547E8D8
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1142N-A-K9
Press RETURN to get started!
*Mar  1 00:00:0
               *Mar  1 00:00:11.925: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:57.018: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Mar  1 00:00:57.019: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:57.020: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:00:57.038: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:57.038: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:58.008: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:58.018: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:58.018: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
ap>
At any rate I managed to get in I used  Cisco with  capital  C  which I swear I had done  a couple of times  before  and it worked.
Haha. At least you figured it out
Scott Fella
Sent from my iPhone
-Scott
Thanks for your help I like it when i have someone to bounce ideas off  it gives me a focus and helps  troubleshoot better.
No problem. That's what's nice about this forum:)
Scott Fella
Sent from my iPhone
-Scott
I just did this for a customer. He had 1142 AP with autonomous image but password was lost.
I pressed the mode key for 5 sec and released. The ap rebooted with factory defaults, it kept the ip address
like they have usually done before.
By pressing the key for 9 seconds or more you go for a software-recovery. So be sure you need that.
You see clearly the console reports. "Mode button pressed for mor than 9 secons, waiting to be released"
then the AP takes a 10.0.0.x IP by default and broadcasts for x.tar.default image.
By having a TFTP server with 10.0.0.10 for example and the image ready, the software can be changed
from lwap to ios (autonomous) for example.
