Roaming between radios
mtotelenivel1
Level 3
Level 3
Hello to all!!
I`d like to know if roaming it's possible between radios. I mean: I've some ap with radio a and b/g/n and other only with b/g/n, client roaming between them is possible??
thanks in advance!!
Leo Laohoo
Yes it is very possible as long as you have signal overlap.
Stephen Rodriguez
to add to Leo, so long as you have overlap and the SSID are configured the same, you should roam just fine between AP.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
