Showing results forĀ
Search instead forĀ
Did you mean:Ā
Roaming between ssids
vishalpatil86
Level 7
Level 7
hi,
is roaming possible between two ssids? if yes,then  how?
George Stefanick
Hi Vishal,
Romaing is between Access points that share the SAME SSID and security.
Can you chnage or prioritize WLANs, yes. This can be done in the suppicant. but it wouldnt be "roaming"...
You care to share what you are trying to do ?
