Roaming between two different model of Autonomous APs?
peng
Currently have Cisco AP541Ns which are in a cluster and will like to add an different model AP into the network, which is the WAP551.
I would like the same SSID config on both so clients can do roaming between the two without issues, Can you see a issue with roaming with the two different models?
Ravi Singh
Level 7
Level 7
Client roaming should work just fine... in theory. Just double-check and make sure the SSIDs, passwords, and authentication types are identical on each AP.
Ravi Singh
Level 7
Level 7
Venkatesh Attuluri
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/RToWLAN/CCVP_BK_R7805F20_00_rtowlan-srnd/CCVP_BK_R7805F20_00_rtowlan-srnd_chapter_0101.html#CCVP_RF_R1BC7593_00
