Roaming issues
I'm having roaming problems at a customer.
I have 1 WLC 5508, software version 7.4.110.0 and 20 AP (AIR-CAP1602I-T-K9) installed on the head office and 15 AP x 3 Branch office.
The roaming problem occurs at all sites, even using 2.4 or 5 ghz and with any devices, laptop, mobile, tablets.
Sometimes the connection drops, other times I need to disconnect and connect again to the WLAN.
Sometimes I have poor signal, even if I move bellow another AP, the roaming doesn't occur.
Troubleshootings that I did:
Site survey using Airmagnet Pro, there is some others SSID on same channels (2.4 GHz, 5 GHz)
Debug tracking an user mac address, but nothing was found.
DCA channels config to default, DCA channel list remains 1,6,11.
Additional information: This issue also occurs using 802.1x or WPA PSK.
Should I use static channels?
Any advice is welcome.
Thanks.
6 Replies 6
Scott Fella
You need to make sure your using WPA/TKIP of WPA2/AES, not a mix of either or both at the same time.  Try that first as you have no issues with other authentication methods, so no need to change anything else.
-Scott
Hi Scott, thank you for answer.
I've just tested with WPA2/AES and the issue is still happening.
I tried without authentication and still occur.
At this moment I have 525 Rogue APs listed on WLC... May I disable A/B/G/N low data rates, is this a possible issue?
can you share, show WLAN <id> + debug client <client MAC >
I've attached the info.
in the debug output i can't see any reassociation request from the client ,
if this debug collected while the client is roaming between two APs , then the issue is either a coverage hole or a client side issue ,
 please share traplog
Thanks for helping I've disabled the data rates under 11mb from both 2.4 and 5 GHz. The roaming issue is no longer happening.
