Roaming parameter adjustment for AP Roaming
keith-mk-li
Dear All,
          I have a question would like to ask regarding on the roaming parameter -dBM adjustment, in WLC 9800L where i can adjust this parameter to -67 dBM ? any help would be appreciated
Keith
7 Replies 7
Leo Laohoo
Wireless client is responsible for making roaming decisions.
keith-mk-li
may i ask in advanced page, which option field to do that ?
keith-mk-li
or this is the one ?
@keith-mk-li
  As already informed, you can not change the roaming behavior by  changing RF configuration on the WLC as the roaming is a client decision.
This screen you are seeing, is related to the Coverage. Meaning, if you change this, you are going to change the Access Point cells size. You will be narrowing down the AP coverage. Change this parameter carefully or you may and up having coverage issue.
If you want to interfere with roaming, you may use RX-SOP
https://uniquessid.com/2021/05/08/configuring-rxsop-in-cisco-ios-xe-and-aireos-wlcs/
You can also take a look in optimized roaming
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/optimized-roaming.html
But, never forget that the roaming is not WLC decision.
keith-mk-li
may i ask for the RX-SOP, if i leave it as "Auto" most likely the parameter of -dBM is around what ?
RX-SOP controls the entry of clients to the Cell. You need to test this exhaustively before implement. I can not tell you a value as I dont know how good or bad is your wireless coverage. What I can tell you is that the RX-SOP is a filter and makes the AP look in the frame and  accept the client or not.
 If you add a value two high, for example -65dBm, you are narrowing the access point cell a lot as only clients with signal above that will be able to join. In the same way, if you set the value to something like -80dBm, you are basacally allowing anyone to join.
This is not a simple setup. If you want to play with that, dont expect anyone to tell you value. Make your tests and take your own conclusion. No one knows your network. If you have a very good coverage you can work with one range o value but if the coverage is bad, is  something else.
This is the kind of feature that can help but also can bring you a lot of trouble.
Rich R
What is it you're actually trying to do?
Adjusting AP cell size is about about power levels but that should be part of your wireless design and post-install survey.
If you don't know how to do that then you should hire a qualified wireless design professional to do it for you.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
