ROAMING REAUTHENTICATION
Hello.
I have an installation with two WLC,  a WLC 2100 with 12 AP and a WLC 2504 with 3 AP in the same LAN.
When a client is registered with the WLC2100 AP and roaming  to an AP in 2505 WLC, he  need to register again.
It is possible that client will always be validated in a single WLC and not needs to re-authenticate?
Thanks.
Rasika Nayanajith
Have you configured both WLC in same mobility group with same virtual IP address on both of them ? As long as both are in same mobility group you should get smooth roaming.
Also what AireOS version running on 2100 & 2504 ?
Rasika
**** pls rate all useful responses ****
6 Replies 6
Eric Moyers
Level 11
Level 11
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I am sorry to hear that you are experiencing this issue. Since your questions deals with the Wireless LAN Controller, it may be better to ask your question here:
https://supportforums.cisco.com/community/12168506/wireless-lan-controller-config-analyzer-wlcca
Within the Small Business Portfolio, we do not work with WLC's.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
Hi Eric.
I'm sorry.
Thanks for your response.
Abhishek Abhishek
Please paste the outputs of-
debug l2roam [detail | error | packet | all] {enable | disable}
Rasika Nayanajith
Rasika
Hi Rasika.
The solution was to configure both WLC in the same mobility group.
George Stefanick
As Ras points out the mobility domain shares client information between both controllers such as authentication and dhcp. The client is a dumb device in that it doesn't know that AP1 is connected to controller 1 and AP2 is connected to controller 2, it only see SSID: Production. When the client moves to the new controller its like a brand new join .. This is why you are having this issue.
