Roaming setting on a 4404 controller
nh6we
Level 2
Level 2
Can anyone tell me where I would go to verify the roaming settings on a 4404 wireless controller.
Stephen Rodriguez
you would go to:
Wireless > 802.11a/n or 802.11b/g/n > Client Roaming.
But this is only effective with CCX compatabile clients.
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/system_management/config_system_management_chapter_01100.html#ID2718
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Abhishek Abhishek
As per your query i can suggest you the following steps-
Basically there are two types of roaming settings-
Intra and Inter.
For seeing the details of the settings please refer to the link-
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40mobil.html
Hope this will help you.
