Block channels for DFS
Remo Grueebler
Community Member
Hello
For a customer I have configured a workgroup bridge. To improve the roaming the workgroup bridge only scan three different channels (100, 108, 116). When the other access point (not the workgroup bridge) use DFS they can change the channel.
Can I configure the access point that in fact DFS is used it only can change between this three channels?
I hope I could make myself understood.
Regards Remo
6 Replies 6
Scott Fella
Well its not a good idea to actually use the Extended UNII-2 channels as may devices will not support that.  Why not use the unii-3 channels as they are not DFS.  Here is a link to DFS which should help:
http://www.cisco.com/en/US/docs/routers/access/3200/software/wireless/RadioChannelDFS.pdf
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi Scott
Thank you for your reply. I forgot to say that I live in switzerland. As I understand we can't use UNII-3. Outdoor we can use 5.47GHz to 5.725 GHz but only with DFS.
We need a very fast roaming. When the workgroup bridge has to scan all channels from 5.47 to 5.725GHz it is too slow. So I try to find a solution that the wourkgroup bridge has to scan only three channels.
Regards Remo
You can block some bands this way.
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap6-radio.html#wp1170200
-Scott
Yes I know that I can block a complete band. The problem is that when I block the band 1, 2 and 4 the workgroup bridge has to scan the complete band 3. This are 10 channels or something like that. This is too slow in our case. Is there no posibility to block a single channel? Something like: "dfs channel 5500 block".
Regards Remo
Scott Fella
Well... That is how it works. Since your in a band that requires DFS, the AP has to scan periodically as part of regulations.
-Scott
Scott Fella
Your better off finds a band with the least channels and use that.
-Scott
