Rogue AP Policies and Best Practices
DarioPouseiro
Dear Cisco Community,
I am trying to undesrtand the best practices and the best policies to deal with Rogue APs, and many doubts emerged. Let me just clarify that I am just a beginer.
Under Rogue Policies on the Wireless Controller, the AP Authentication, If I select that option is just to confirm what kind of authentication the rogue AP is using when a new one is detected?
When I receive a rogue AP minor alarm, and I identify that it is a harmless Wi-fi access point from a business around the building, what happens if I classify it as friendly? It is a security flaw if I do it? In the future, if that WAP becomes dangerous, how would I identify it? A new alert would be reported if for example the SSID was changed?
Thank you in advance!
Best regards!
 AP Authentication is related to your Access Point, not the rogues. With that feature, you can create authentication for your APs, similar to clients. Sounds like a good idea but can create a lot of problem. I would not recommend.
"When I receive a rogue AP minor alarm, and I identify that it is a harmless Wi-fi access point from a business around the building, what happens if I classify it as friendly? "
 The alarm will not be generated again. If you do not classify as frendly I will be receiving alarms about that AP all the time.
"It is a security flaw if I do it?
 I dont believe so.
"In the future, if that WAP becomes dangerous, how would I identify it? A new alert would be reported if for example the SSID was changed?"
  The only possibility I can see for that AP to become "Dangerous" would be if the AP´s owner start advertising your SSIDs or start the containement for your SSIDs. And this could be identify through others logs also.
Generally I set the rules like this:
Rogue detected with my SSIDs - classify as malicious
Rogue detected with signal -85 - Classify Neigbour and dont worry
Rogue detected on wire - classify malicous
Rogue detected with signal better than -75 then have investigated.
Containement should only be done if the rogue is broadcasting your SSIDs, or is on your wired network - there are legal considerations to containment (https://edition.cnn.com/2014/10/03/travel/marriott-fcc-wi-fi-fine/index.html
Also with containment it affects your APs so it should only be done whilst you are physically finding and disconnecting the rogue AP
*****Help out other by using the rating system and marking answered questions as "Answered"*****
