RSSI LED Indications
amunoz
Frequent Visitor
Frequent Visitor
Hi!
I have two Cisco Aironet 1300, and i want to use the RSSI, my cuestion is..
i need configure two bridges in Install-mode, or only one in instal-mode and the other in root mode?
thanks
thisisshanky
Level 11
Level 11
If you want to bridge between these two, configure one as root, and other as non-root. On the non-root you wont have to set much paramters other than SSID and WEP. Pretty much every thing else will be negotiated from the root bridge.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
