Rx Sop Threshold Default Setting
sn3
Frequent Visitor
Frequent Visitor
Fellow Colleagues,
Is anyone familiar with what the "Default" setting for Rx Sop Threshold represents? This configuration can be found under Wireless > Advanced > Rx Sop Threshold. The other setting options are defined in the help file, but I'm not quite sure what I should take "Default" to mean.
802.11 Band
High Threshold
Medium Threshold
Low Threshold
Custom Threshold
5 GHz
–76 dBm
–78 dBm
–80 dBm
–85dBm—–60dBm
2.4 GHz
–79 dBm
–82 dBm
–85 dBm
–85dBm—–60dBm
We have a 3504 controller running 8.8.120.0.
Many thanks!
Mark Elsen
=  The default threshold at which the Access Point radio starts to acknowledge the Start
 Of Packet (SOP) frame transmitted from a wireless client.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
sn3
Frequent Visitor
Frequent Visitor
Thanks for the response! I apologize for being unclear, but what I meant was that the other settings (i.e. High, Medium, and Low) have an explicit threshold in dBm associated with each. I am thinking that "Default" could possibly mean one of the following or something else I've not thought of yet:
  • Is there some specific number that "Default" is associated with?
  • Does "Default" simply mean that the AP will process anything it hears?
Hopefully this clears things up.
Thank you!
 - As far as I understand it, the default value is not frozen. It relates to the particular AP-model + the capabilities of the particular radios from that AP.
 M.
