Same VLAN in Multiples SSID
Fulvio Ferreira
Level 3
Level 3
Hello.
      Can I use the same VLAN in multiples SSID?
      Here is my config:
dot11 syslog
dot11 vlan-name Multi_TC_Legacy_1_VLAN_InsideFW vlan 400
dot11 vlan-name Multi_TC_RF_GMOL vlan 350
dot11 vlan-name Multi_TC_RF_VLAN_Management vlan 300
dot11 vlan-name Multi_TC_RF_VLAN_Radius vlan 301
dot11 ssid TOOLS
   vlan 400
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 107E080A1646405858
dot11 ssid sjcac-manuf-301
   vlan 301
   authentication open eap eap_methods
   authentication network-eap eap_methods
dot11 ssid z06ctsv
   vlan 350
I would like to know if I can use VLAN 301 in SSID TOOLS and sjcac-manuf-301.
Thanks.
Fulvio Ferreira
George Stefanick
The autonmous mapping is 1-to-1. So no, its not supported.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
if you have a wlc, you can do that .
