Sample TAR for passthrough?
gamccall
Level 8
Level 8
WCS 5.1. I can't find any way to download a sample.tar file from the WCS for a passthrough template, only for a webauth (username+password) template. Is it in there and I'm just blind? Or is there anyplace else I can find a tar bundle template for a "check the box" passthrough splash page?
7 Replies 7
Robert-ITS.Thomas
Community Member
having the same issue, hope someone can shed some light on this.
Here is one I sort of modified... you can delete the decline button if you wish.
-Scott
can you help on how to convert mi htm files to .tar?
Post your files and I can tar it up for you.
-Scott
If you are a windows user, google "tar windows" and get the 1.13 binaries. Once you have it installed and operational, you can modify the following command to take your login.html and image files and make them into a tar file. On my computer, for simplicity, the login.html is in the root of C:, and my images are in the c:\images subdirectory.
c:\progra~1\gnuwin32\bin\tar -cvf test.tar login.html images/logo_bar.jpg images
/new_logo.jpg
grzegorz.ciolek
Level 3
Level 3
You can use 7zip free software to tar files. www.7zip.org.
Cheers
As grzwgorz pointed out 7zip works great... i just used it to tar up my new guest page ... works like a charm !
