03-28-2014 05:53 AM - edited 07-05-2021 12:34 AM
I am working on tunneling a wireless network with the following components:
wlan-controller-14-4 impa-wireless4 --> AIR-WLC2106-K9
wlan-controller-14-2 impa-wireless2 --> AIR-WLC2106-K
11 AIR-LAP1131AG-A-K9
10 AIR-LAP1252AG-T-K9
They are geographically distributed on four floors in the same building.
I have configured RRM feature on both 802.11 a/n and 802.11 b/g/n
A Samsung Galaxy note, Android 4.1.2, stock + rooted can not connect,
although having a high level sign.
I have been seen messages like above
Mar 27 12:43:04 wlan-controller-14-4 impa-wireless4: *dot1xMsgTask:
Mar 27 12:42:57.710: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444
Max EAPOL-key M3 retransmissions exceeded for client
50:cc:f8:86:80:7e
Mar 27 13:28:44 wlan-controller-14-2 impa-wireless2: *dot1xMsgTask:
Mar 27 13:28:37.526: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444
Max EAPOL-key M1 retransmissions exceeded for client
50:cc:f8:86:80:7e
Mar 27 13:30:03 wlan-controller-14-2 impa-wireless2: *dot1xMsgTask:
Mar 27 13:29:56.714: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444
50:cc:f8:86:80:7e
Mar 27 14:00:34 wlan-controller-14-4 impa-wireless4:
*apfMsConnTask_0: Mar 27 14:00:27.740: %APF-4-ASSOCREQ_PROC_FAILED:
apf_80211.c:3240 Failed to process an association request from
50:cc:f8:86:80:7e. WLAN:1, SSID:impa-nwl. mobile in database timed
out.
Any idea?
03-28-2014 11:42 AM
What AireOS version running on these two controllers ?
Are they in the same mobility group & mobility configured each other ?
Attach the "show wlan <wlan-id>" output to see how you configure the SSID.
Rasika
*** Pls rate all useful resposnes ****
03-28-2014 12:12 PM
impa-wireless4 : Software Version 7.0.235.0
impa-wireless2 : Software Version 7.0.235.0
Yes both controller are on Local Mobility Group impa-wl-novo
Keep Alive Count 3
Keep Alive Interval 10s
Symmetric Mobility Tunneling mode Enabled
WLAN Identifier.................................. 1
Profile Name..................................... impa-nwl
Network Name (SSID).............................. impa-nwl
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 134
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ wifi-clients
Multicast Interface.............................. Not Configured
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ Disabled
Accounting.................................... Disabled
Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
802.11 Authentication:........................ Open System
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Enabled
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled
WPA2 (RSN IE).............................. Enabled
Auth Key Management
802.1x.................................. Disabled
PSK..................................... Enabled
CCKM.................................... Disabled
FT(802.11r)............................. Disabled
FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
H-REAP Local Switching........................ Disabled
H-REAP Local Authentication................... Disabled
H-REAP Learn IP Address....................... Enabled
Client MFP.................................... Optional
Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID IP Address Status
DSCP Value 0
no Mutlicast config
03-28-2014 01:04 PM
Try this with disabling WPA/AES option highlighed below. Just leave WPA2/AES under WLAN security settings
If that does not succeed please provide "show mobility summary" output as well just to confirm mobility is working fine.
Rasika
*** Pls rate all useful responses ****
03-28-2014 01:58 PM
I have already done
WPA (SSN IE)............................... Disabled
Auth Key Management
mobility status is up
let's wait and see what goes on
