Schedule WIFI using Prime 3.3.0
torchri
Im trying to schedule a wlan to disable and enable it again after a specific a period of time. I get an snmp error MIB access failed. SNMP Community may not have write permission, check and try again. : xxxxxxx:x.x.x.x
as image attachent shows.
I cant find where to select/input this snmp community to the task. Prime monitors the WLC properly, so Im currently stuck. Any advice?
when you setup the WLC in Prime did you use the RW community for SNMPv2c?
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Thank for fast reply. This pointed me to the correct place. I see now that the the SNMP v3 user we specified in Prime only have only read permissions on WLC. I have to replace this user with a ReadWrite user who is present on the WLC. But Im a bit worried how this impact the current connection/configuration between the WLC in question and PRIME. I of course dont want to accidentially loose configuration for our maps and alarms for this controller present in PRIME. Is there any caveat here I should be aware of?
