Scheduling WLAN key Changes With NCS Prime
JASON SIMMONS
Level 2
Level 2
Is there a way to schedule WLAN key changes using NCS Prime? How?
I need to change the key to a WLAN on 3 different controllers weekly at a specified time. Shouldn't I be able to do something like this in NCS Prime?
Amjad Abdullah
You can use cli template if the is no template alrady available.
Rating useful replies is more useful than saying "Thank you"
Scott Fella
There is no way you can set a schedule... Like AA mentioned, you can create a cli command template and just push it out. Or if your good with scripting, you can script something to login to each wlc and send the command to change the psk.
-Scott
