Script based config for AP340, AP350, and AP1200
jplunk
Level 4
Level 4
I have tried to relocate a document that I saw on cco about 6 months ago on how to use the variables for the AP340, AP350, and AP1200 to create a config script that you could upload as an .ini. Does any one know how to do this or where the document is? I need to be able to put in users into the user database as well as input radius, and tacacs servers and the shared secrets for them. Any ideas or solutions are appreciated.
fbarook
Can you let me know the exact Title of the Document or the URL?
I wish I knew what it was, then I could help you find it, or find it myself. It was a document on / in the configuration guide for the Access Point software. I was searching for something else that day and ran across this document that detailed every variable that is stored in the ini file that you can download from the Access Point.
Look at the MIB files (both IEEE and Aironet prorietary). There's should be enough internal descriptions to provide what you need.
