second guest wlan
lldemeyer
Currently we have a WLC anchor controller running V4.2.130 . And it has one real Guest wlan which is directed to the Internet .
I would like to know if we can configure another Guest-like wlan on the same anchor WLC. The aim is to create a second Guest-like wlan on our anchor WLC and direct it to our internal firewall . So that users associating to this Guest-like wlan no matter where they are located in our network get a dhcp address in the same subnet and we can configure our internal firewall so that these users are limited to certain resources .
If it is possible , can you provide an example of a setup ?
dennischolmes
Level 11
Level 11
Each Anchor can support up to 71 EoIP tunnels but only one from each controller. So no, it is not supported by Cisco at this time. These controllers can be from different mobility groups but only one tunnel per WLC is currently supported. Stay tuned as the next generation of controllers is unveiled. You will see some significant changes with how these controllers operate.
