02-22-2013 06:31 AM - edited 07-03-2021 11:36 PM
Hi all,
We have 2 WiSM2 running. Now I'd like to add some Accesspoints as OfficeExtend. As the WiSMs are in our internal network and not in the DMZ, so I thought easiest would be to create a new interface on the WiSM with a DMZ-IP which would be reachable from outside (with static NAT).
Does anyone know if this would work?
Thanks a lot
kind regards
Thomas
Solved! Go to Solution.
02-22-2013 06:32 AM
No... It's required to use the management IP address because that is the interface in which you have to specify the NAT address.
02-22-2013 06:32 AM
02-26-2013 02:27 AM
Too bad, as his would make it much easier to separate the local network from the "remote accespoint network".
Thanks for your answer
