Seeing a recurring message when running debug on IIoT device
kkunimoto
Visitor
Hello, I'm seeing this message consistently when running a debug client <mac> command:
*apfReceiveTask: Oct 06 07:43:19.454: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:22.922: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:26.388: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:34.957: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:38.833: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:42.097: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:43.525: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:46.382: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:46.993: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:50.665: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:54.133: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:43:57.600: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:44:06.168: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:44:14.737: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:44:23.305: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:44:31.871: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:30.260: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:33.512: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:36.764: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:45.083: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:48.551: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:51.778: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:55.027: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:55.639: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:58.250: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:45:58.851: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:46:02.050: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:46:06.451: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
*apfReceiveTask: Oct 06 07:46:09.850: [PA] apfMmProcessMessage: Freeing the mm pkt for non existing client
Can anyone tell me what this message means? Any Cisco documentation you could point me to?
TIA!
Rich R
What WLC?
What software version?
What model of AP?
Have you run the debug results through https://cway.cisco.com/wireless-debug-analyzer/ ?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
