Separate mgmt and AP_manager VLANs in Virtual WLC
5mlarsson
I would like to have the vWLC management and "APmanager" functionality on separate VLANs. For security reasons I don't like exposing the manager IP to all places where I place APs. But when I disable DYNAMIC-AP-MGMT on the management if and enable it on another IF the VWLC complains that the JOIN message comes in on a wrong VLAN and rejects the  AP join.
Is it possible to separate the mgmt and APManager to different VLANs? Maybe to use the out of band service port for mgmt and put an CPU access list on the data port to block exposed mgmt protocols like https?
Or did I misunderstand how this is supposed to work?
Scott Fella
I don't think you can do this with a vWLC, but in general, the newer code, AP's still had to communicate via the management before it tries to use a dynamic interface.  You would have to play around with the VM and create multiple vlans and try to map those properly, but again, I haven't used many vWLC.
-Scott
-Scott
