Separate VLAN for WPA - Cisco 1100
eddy_isere
Cisco 1100 :
First config. : no vlan with WEP for access network
But when you create a vlan for wpa-psk with simple config (no server manager, no radius, no eap), have you to modify the other peripherals networks (router...).
For example to declare the vlan.
I did not find this information in the documentation of the aironet 1100.
Thank you for your help.
Eddy
drolemc
Level 6
Level 6
There is a good document on Cisco.com which explains how to configure WPA-PSK. The document is available at
http://cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml#pers
If you are still having issues configuring wpa-psk, please post the configuration so that we can troubleshoot the issue.
