04-21-2011 02:26 AM - edited 07-03-2021 08:06 PM
Hi all, i 'm trying to connect to our aironet through the serial connection but there is no output on the terminal.
Please help.
Solved! Go to Solution.
04-23-2011 07:12 AM
Check your cable too:
George wrotes already the right default console settings..you could try flow control Xon/xoff too if nothing is working..
Or somebody changes the default settings..
Console Port | PC COM Port | ||
RJ-45 | DB-9 | ||
Pins | Signals | Pins | Signals |
1 | NC1 | - | - |
2 | NC1 | - | - |
3 | TXD2 | 2 | RXD3 |
4 | GND4 | 5 | GND4 |
5 | GND3 | 5 | GND4 |
6 | RXD5 | 3 | TXD2 |
7 | NC1 | - | - |
8 | NC1 | - | - |
1 NC indicates not connected. 2 TXD indicates transmit data. 3 RXD indicates receive data. 4 GND indicates ground. |
04-21-2011 02:40 AM
Try opening with Hyperterminal and while using that, restore default the conection with Baud rate as 9600 and etc and lemme know if we are still facing the issue..
Wats the console cable that we are using??
Surendra
04-21-2011 04:36 AM
I'm using a blue rollover cable(RJ45-db9 sesrial), even copying the ios into the AP is an issue, it keeps timing out :-(
04-21-2011 05:54 AM
make sure that you are plugging the console cable in the console port since both ethernet and console are RJ45
After that then it should work, if you are using a USB to serial adapter, make sure it works with other netwoek device, if possible test it with another AP.
once connected, make sure you reload the AP with power supply and you should at least see someoutput.
How are you performing the IOS upgrade?
04-21-2011 06:16 PM
04-23-2011 07:12 AM
RJ-45 | DB-9 | ||
1 | NC1 | - | - |
2 | NC1 | - | - |
7 | NC1 | - | - |
8 | NC1 | - | - |
04-25-2011 11:32 PM
Thank you all for your informative and useful help, it turns out i had a faulty rollover and ethernet cables(what are the odds :-o). Everything is working ok now :-)
04-26-2011 08:03 AM
ok, great, dont forget to rate the posts...
HAve a good day!
