set up guest wireless
gerardobrien
Visitor
Hi All..
I'm having some problems setting up a guest wireless.  First of all let me explain out set up
1 x ASA Firewall
3 x SF 300-24P 24-Port 10/100 PoE Managed Switch's
6 x AP541N-E-K9
We have set up the company wireless which worked fine.
However i am trying to set up a isolated guest WiFi.
Any ideas or best practics on how to do this?
Scott Fella
You might want to post this in the small business wireless forum. You would probably get better luck there.
-Scott
thanks! just noticed the group it was in!
Abhishek Abhishek
Set up the Modem with a second static IP and configure the access point to use it.
It's down to weighing the cost of a VLAN capable switch versus the cost of the extra IP address.
