Outdoor controller based Bridge
Santosh Shetty
Level 4
Level 4
                   Looking for setup controller based wireless bridge or AP to cover 300m X 300M ground area. Need to know wireless ap , antennal to support for setup.
Scott Fella
The only bridge a WLC can support is Mesh. Now will it cover a 300m x 300m. I don't think so. You would need multiple mesh units and most likely need to survey unless its a wide open area. The 1552's with external antennas (only one type if antenna) is probably what you need to look at.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps11451/data_sheet_c78-641373.html
-Scott
Abhishek Abhishek
You can find the bridge range calculation utility tool here-
http://www.cisco.com/en/US/products/hw/wireless/ps458/products_tech_note09186a008009459b.shtml
