Setting a Port Number for WLC Syslog
fdharmawan
Level 4
Level 4
Hi Guys,
Is it possible to set up a port number for syslog on WLC 5520? On the switch we can set it up by issuing the command logging "host 192.168.100.100 transport udp port 5678", but so far I did not find it for WLC.
unfortunately not - well if there is a way i haven't found it
the command is config syslog <IP> or config syslog disable no options to add a port
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Hi Haydn,
Thank you for the reply. So the syslog package will be forwarded using UDP 514?
