Setting up AP's on a Cisco 3650
Greetings fellows,
I need help on how to setup Cisco Aironet1851i on a Cisco 3650 switch.
I would appreciate any kind of help or resource referral to check.
Nkosana
Mark Elsen
                                            - Check if this guide is helpful :
                 https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3e/lwap/configuration_guide/b_ap_3e_3650_cg/b_ap_3e_3650_cg_chapter_011.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Sandeep Choudhary
Thanks for the posts will use them to master mobility Express, currently I'm searching for a resource I can ref on how to add more AP's on a 3650 integrated  controller
