Replacement Power Supply for AIR-CAP3702I-E-K9
jmar83
Hi there
Where can i get a replacement oower supply for the AIR-CAP3702I-E-K9 access point? When i mail to Cisco Switzerland (cs-support@cisco.com), i don't get any answers. And i wrote at least 5 mails (in 3-4 weeks) but i never got an anwser. This is not serious in my opinion.
So where the get an original replacement for the AIR-CAP3702I-E-K9? Maybe from another supplier if Cisco is not interested to make business with me. E.g. from a reseller shop, distributor, used or refurbished ones - whatever.
Thank you very much for your feedbacks.
With kind regards from Switzerland,
Jan
2 Accepted Solutions
It's a current "property" of the forum, should be fixed in the future.
Send me a PM with your private (Swiss) address and I can send you one. They are one step before trash here.
Oh and no, that P/N is the wrong model.
7 Replies 7
kubn2
cs-support shouldn't be used to report faulty parts. Have you raised RMA/TAC case? Please check below:
https://www.cisco.com/c/en/us/buy/product-returns-replacements-rma.html
Sandeep Choudhary
Its already end of sale.
Replacement product for 3702I AP is 3802:
here is the info:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-3700-series/eos-eol-notice-c51-740710.html
AIR-AP3802I-E-K9
If youstill wnat to use 3702 then would have to purchase the pwrinj4 from another place.
Dont forget to rate helpful posts
jmar83
Hallo
OK, so the product name for the power supply for my access point is "pwrinj4" ?
Thank you very much!
Best regards,
Jan
jmar83
Why i get e-mail-notifications about my own posts? How to turn off that feature?
THank you for your feedback.
Regards, Jan
jmar83
And: The only one power supply i have (but i have 3 access points) is the one with that data:
P/N:
34-1977-03 Ao
Model:
PSA18U-480C
Input:
100V-240V
Current:
0.5A
Frequency:
50-60Hz
Output volts:
48V
Output current:
0.38A (=380 mA)
Is that one equivalent to the one you told me, the "pwrinj4" ? Or is it the wrong one??
Thank you very much for your feedback.
With kind regards,
Jan
