Setting UP Cisco 5508 WI-LAN CONTROLLER
okoroji80
Dear All,
I need a basic explaination on setting up the following controller:
Cisco 5508 Series Wireless Controller for up to 100 APs
802.11a/g/n Ctrlr-based AP w/CleanAir; Ext Ant; E Reg Domain
For Mobility i want to settup the device such that the SSID would be thesame
with thesame security key and in different subnet.
Jude.
5 Replies 5
Saravanan Lakshmanan
yes it works, it is called L3 roaming, on roaming client will keep the original ip from received from initial subnet.
My concern is that i have not worked on this model of controller before now.
could you assst with the basic set up
Here is a link to help you get started
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml
-Scott
Thanks Scott. but can i get a downloadable PDF USER GUIDE FOR THIS.?
Use the link and on the right top corner you can download it as PDF.
