Using the 1262 AP in Workgroup Bridge Mode
rodoneal09
Client has a building that is located 300Ft apart and would like to provide IP communications for 3-4 IP hadsets back to an IP PBX.   They do not want to dig up the parking lot so we proposed using a wireless bridge.   I noticed that Cisco discontinue the 1300 and 1400 Wireless Bridge.   Can I use a 1262 with external antenna in Workgroup Bridge mode to perfom this functions?   I will put a Layer 3 switch on both ends to route traffice (3560C-8).   Should I use the Yagi antenna's for outdoor use?   Thanks!
Stephen Rodriguez
You could go WGB, but root/non-root might work better. This will allows you to pass multiple VLAN across the link.
This is a bit old, but it' the Bridge Range utility
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps458/prod_technical_reference09186a00800a912a.xls
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
