setting up my ap 3700
riyas2khan
1) Can we configure AP AIR-CAP370I-E-K9 (atonomous)t o make the user from the organization to authrize automaticaly by MAC filtering without provide any credential.? how ?
2) (atonomous) can we create guest access with limited time access.  how ?
I dont have any WLC.
5 Replies 5
Rich R
I've never tried to do anything like that or seen it done on autonomous.
Look through the config guide and see what you can come up with:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/atnms-ap-8x/configuration/guide/cg-book.html
Rasika Nayanajith
Refer below for guest access using autonomous AP
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/116897-configure-technology-00.html
MAC filtering as a security measure is not recommended. anyone can spoof a MAC address very easily
Rasika
*** Pls rate all useful responses ***
Thanks Mr.Rasika,
is there any guide to configure the same through GUI instead of CLI. i am not an IT expert. i am very rookie to this.
With Autonomous AP, sometimes GUI may be a bit flaky. I  haven't seen any recent documentation from Cisco for it as Autonomous mode does not continue to support it. (in favor of Mobility Express/EWC mode)
I would simply get into CLI (SSH or console) & try that configuration guide
Rasika
Rich R
