Setting up WDS
amir
Community Member
I have a customer that needs to extends its wireless network wirelessly. All the AP:s (AIR-LAP1242AG-E-K9) are managed by a WLAN Controller (AIR-WLC2106-K9). One of the AP needs to be extended, which i'm guessing, with WDS. This AP needs to have a couple of devices connected to with cable.
(WLAN Controller) ----- wireless ----- (Access Point) ------ Wired ------ (Wired Devices)
Is this setup possible?
Surendra BG
Amir,
Its not called as WDS.. WDS is a Autonomous terminology... we need to use WGB (Work Group Bridge)..
here is the link to get its up and running..
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080905cea.shtml
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Surendra BG
Amir,
Surendra
Surendra BG
amir
Community Member
Thank you so much. That's exactly what i was looking for
Thanks Surendra for your contribution on CSC and helping Cisco Partners.
Vinay Sharma
Community Manager - Wireless
Thanks & Regards
