Settings locked!...
steffenluttge
Just received the 7921, and wondering how to unlock the settings.. ?
The manual just says: contact your system administrator... ohh gee - I?m the SA...
Steffen
Rob Huffman
Hi Steffen,
Have you tried this method?
Accessing Network and Phone Settings
You can view and change many network configuration options and phone settings for the Cisco Unified Wireless IP Phone 7921G by using the Settings menu.
Note You can control whether a Cisco Unified Wireless IP Phone 7921G has access to the Settings menu from the Cisco Unified CallManager Administration Phone Configuration page. Use the Settings Access field in the Product Specific Configuration section of the phone configuration page.
To access the Settings menu, follow these steps:
Procedure
Step 1 Press on the Navigation button for (Settings).
Step 2 Use these menu options to view or change settings:
Phone Settings
Network Profiles
Security Configuration
USB Configuration
Note: These options are configurable; other options are display only.
Step 3 To select the item that you want to configure or view, do one of these actions:
Use the Navigation button to scroll to the item and then press the Select button.
Use the keypad to enter the number that corresponds to the item.
Step 4 **If a menu option is locked , you must press ** # on the keypad.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a008079b4ce.html#wp1328723
Hope this helps!
Rob
6 Replies 6
Rob Huffman
Hi Steffen,
Procedure
Phone Settings
Network Profiles
USB Configuration
From this doc;
Hope this helps!
Rob
Briliant..
thanks
Steffen
Hi Steffen,
Thanks for the nice words and rating! It does hurt when we are the admin people and we are supposed to consult with ourselves 🙂 It always strikes me as somewhat ironic when this happens.
Take care,
Rob
Hi again
Can I use the 7921G with CCM 4.13 ??
And in the 7921G documentation, it gives a webadress where I can DL the USB drivers - but the web adress is empty ?
Steffen
Found it...
S
The 7921 is supported on CM 4.1 and higher.
For USB drivers this is available on the software site @ http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser-crypto.
