SETUP
djdoripan
Community Member
Hello Guys!
First of all sorry if i requested this information out of the right session!
Im beggin on it!
I use a chromecast in my room and i had been using it very well until friday.
Since Friday i have been problems configuring it!
When i try to log my chromecast in my wifi net it says: " Impossible to connect to your wifi net."
I tested my chromecast in others wifi and it work well... only in my wifi have been problems.
anyone can help me with some setup config to my router?
The Google posted a list with some compatibility routers.. but mine isn't on the list.
https://support.google.com/chromecast/table/6207416?hl=pt-BR&ref_topic=3058948
i have a Cisco DPC3928S DOCSIS 3.0 2-PORT Voice Gateway
Saurav Lodh
Level 11
Level 11
Found one post
https://community.shaw.ca/thread/16046
gohussai
Level 8
Level 8
Check the official google help portal.
https://support.google.com/chromecast/troubleshooter/2995236?
Note: Enter the correct SSID and pre-shared key (password) from the sticker on your Cisco modem, you should be okay. Reset the modem and the Chromecast if you're still having issues.
