webauth for external WLC
zappo0305
Level 3
Level 3
I have a organisation (using meraki WLC) and they wants to access our NAC guest server via webauth. Internally we have Cisco WLC with Cisco NAC guest servers.
What are the best way so achieve the objective above?
Would you recommend having the Merika WLC with external webauth, point it to our internal NAC guest server (which we have to open port 1812 and 1813).
Dont know where to go for advice. Hopefully some one can share their experience. Thanks in advance.
Check the below configuration link for centralized web authentications
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/115732-central-web-auth-00.html
External Web Authentication Using a RADIUS Server
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112134-external-web-radius-00.html
WLC – Web Authentication
https://rscciew.wordpress.com/2014/06/19/wlc-webauth-configuration/
