06-05-2012 02:08 PM - edited 07-03-2021 10:15 PM
We are starting an Wireless infrastructure project and up until yesterday, WCS plus was the way we were going. Now I have been reading about NCS and Prime. What are the facts concerning WCS and which product is going to be the flagship into the next 3-5 years?
06-05-2012 11:49 PM
NCS support WLCs that run code from 4.2 to 7.2 and WCS support ends at WLC running 7.0.
Almost, all non EOL WLCs supported on code 7.0 i.e, legacy & new WLC platform that can be managed using WCS or NCS. If you prefer to update the WLC platform that supports 7.2 i.e, 2500, 7500, 5500 & Wism2 then those WLCs can't be managed by WCS. And future WLC that will be released also can only be managed with NCS.
Software Release Compatibility Matrix:-
End-of-Sale and End-of-Life Announcement for the Cisco Wireless Control System Legacy Licenses
http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/end_of_life_c51-556750.html
06-06-2012 10:28 AM
If you have WLCs like the 2100 or 4400 they go up to code 7.0 so you will need a WCS to manage them, but if you have WLCs that support code 7.2 or higher like the 5500 or 2500 then you will need a NCS to manage them.
06-08-2012 03:41 PM
Simple!
NCS is the way because you are expecting to use the new code versions.
And be aware that the last app support will be in February 28, 2013
PS: I migrated from WCS to NCS and got NO problem till this day.
10-10-2012 09:18 AM
Does it mean NCS does not support the 2100 or 4400 WLCs?
