Show AP LAN interface speed
patoberli
Hello All
I currently discovered that two of my APs are running with 100 Mbit/s instead of 1 Gbit/s. This clearly can give a few issues with 802.11n speeds. The affected APs are 3502. They are managed through two WiSMs (7.0.250.0). Those are managed through PI 2.1.
Is there some possibility to see the interface speed of all APs in one place, or do I really have to select every single AP and check the interface speed?
Patrick
GUI is the worse for gathering large amount of data.... try this command from the CLI of the WLC:
show ap stats ethernet summary
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
-Scott
10 Replies 10
Leo Laohoo
You can view the speeds of your APs from the switch.
That's true, but would also mean to login to nearly 100 switches and check the interface. They are not in PI.
I think your out of luck if you are trying to get this data from the WLC.  You would have to look at each switch.
-Scott
To bad 😞
The data is in WLC (Monitor -> Accesspoint -> click one -> Interfaces -> click Gigabitethernet0), but would have hoped to see it with less clicks.
I think that would not be just useful for us, what do you think?
Scotty
-Scott
Great! That was exactly what I was searching for 🙂
Then you can use the show ap cdp neighbor all to find out what switch and port it is connected to.
Scotty
-Scott
Abhishek Abhishek
Abhishek Abhishek
Use the command-
Ben Crissman
Frequent Visitor
Frequent Visitor
I was searching for 9800's and this old thread popped up. so ill update for 9800's too.
AirOS old controllers = show ap stats ethernet summary
9800's = show ap ethernet statistics | inc AP Name|Mbps
