Show power status - 9800-40
thewifidude
Anyone know how to view the power supply status? I got notified by NOC that PSU0 failed but I can only check inventory status on controller. You used to be able to determine power supply status right on the front page in AireOS.
Show platform is the command. Wish this was still in the GUI.
Chassis type: C9800-40-K9
Slot Type State Insert time (ago)
0 C9800-40-K9 ok 17w2d
0/0 BUILT-IN-4X10G/1G ok 17w2d
R0 C9800-40-K9 ok, active 17w2d
F0 C9800-40-K9 ok, active 17w2d
P0 C9800-AC-750W-R ok 17w2d
P1 C9800-AC-750W-R ok 17w2d
P2 C9800-40-K9-FAN ok 17w2d
Slot CPLD Version Firmware Version
0 19030712 16.10(2r)
R0 19030712 16.10(2r)
F0 19030712 16.10(2r)
6 Replies 6
Arshad Safrulla
sh environment all in CLI
This doesn't give me a status whether it is failed or not. Just voltage readings.
Sensor List: Environmental Monitoring
Sensor Location State Reading
Vin P0 Normal 206 V AC
Iin P0 Normal 1 A
Vout P0 Normal 12 V DC
Iout P0 Normal 9 A
Temp1 P0 Normal 26 Celsius
Temp2 P0 Normal 23 Celsius
Temp3 P0 Normal 30 Celsius
Vin P1 Normal 204 V AC
Iin P1 Normal 1 A
Vout P1 Normal 12 V DC
Iout P1 Normal 10 A
Temp1 P1 Normal 24 Celsius
Temp2 P1 Normal 22 Celsius
Temp3 P1 Normal 26 Celsius
VRRX1: VX1 R0 Normal 749 mV
VRRX1: VX2 R0 Normal 6874 mV
VRRX1: VX3 R0 Normal 1214 mV
VRRX1: VX5 R0 Normal 1214 mV
VRRX1: VP1 R0 Normal 1711 mV
VRRX1: VP2 R0 Normal 2488 mV
VRRX1: VP3 R0 Normal 1308 mV
VRRX1: VP4 R0 Normal 5066 mV
VRRX1: VH R0 Normal 11914 mV
VRRX2: VX1 R0 Normal 852 mV
VRRX2: VX4 R0 Normal 1013 mV
VRRX2: VX5 R0 Normal 1014 mV
VRRX2: VP1 R0 Normal 3301 mV
VRRX2: VP3 R0 Normal 1806 mV
VRRX2: VP4 R0 Normal 1052 mV
VRRX2: VH R0 Normal 11924 mV
VRRX3: VX1 R0 Normal 995 mV
VRRX3: VX2 R0 Normal 1004 mV
VRRX3: VX4 R0 Normal 750 mV
VRRX3: VX5 R0 Normal 749 mV
VRRX3: VP1 R0 Normal 2485 mV
VRRX3: VP2 R0 Normal 1195 mV
VRRX3: VP3 R0 Normal 1510 mV
VRRX3: VP4 R0 Normal 1514 mV
VRRX3: VH R0 Normal 11940 mV
Temp: RCRX IN R0 Normal 24 Celsius
Temp: RCRX OUT R0 Normal 36 Celsius
Temp: Yoda R0 Normal 41 Celsius
Temp: XEPhy R0 Normal 44 Celsius
Temp: CPU Die R0 Normal 43 Celsius
Temp: FC FANS R0 Fan Speed 50% 24 Celsius
Mark Elsen
                                                            >.... I got notified by NOC that PSU0 failed
  How was this message received and or which notification-protocol was used by the controller -> show the exact message too. Perhaps show tech can provide more info's (not sure).
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
just that Chassis 1 Power Supply Module 0 - failed
via SNMP
I'll just submit a TAC. Hard to believe there's no easy status to check on these hot swappable components.
Rich R
Try:
show log
show env summ (min/major alarms in last column)
show facility-alarm status
agreed it's weird that they've removed the PSU status from the show env output!
