signal strength of Cisco access point 1130
techguy
Level 4
Level 4
I want to know that what's the maximum range (distance) of Cisco ap 1130. How can I configure to increase the signal strength. 2.4 ghz or 5ghz is best to configure. Shall I extend the range by installing external antenna? Does 1130 support external antenna?
11 Replies 11
Stephen Rodriguez
The answer to that is it varies.  All depends on what is in the area of the AP, what power level and what data rates you have configured.
And the 1130 is internal antenna only, so you are not able to attach an external antenna.
What are you looking to do?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
1130 does not support external antenna. For more information do refer to the datasheet of 1130
http://www.cisco.com/en/US/products/ps6087/index.html
Scott Fella
Put it this way.... If your AP is at default and you only added the basic configuration and SSID's your running at the highest TX available data rates. You will not get any better than that.
-Scott
Saurav Lodh
Level 7
Level 7
Inorder to have better signal experience,
>>Replace devices in your place that can interfere with network traffic on the 2.4GHz frequency range or switch to 5Ghz operational frequency!
>>Check your router's signal strength with these devices. Compare power levels when each device is on and off to determine if they are the cause of your signal problems.
>>switch to different channels.
>>SWitch to 802.11n standard as it offers far greater range and signal strength compared to 802.11 a/b/g.
>>Reposition your AP and Antenna
>>Be aware of external interference.
>>Raise your transmit power ( configure the radio interface settings )
>>Replace the Antenna if needed, as sometimes due to faulty antenna, power loss is observed.
Thanks All,
how to configure power rate and data rate in ap?
how to change radio interface settings in this regard.
If i will configure the ap in 5ghz then strenght will be better?
Configuring Radio Transmit Power
Beginning in privileged EXEC mode, follow these steps to set the transmit power on access point radios:
Command
Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
interface dot11radio { 0 | 1 }
Enter interface configuration mode for the radio interface. The 2.4-GHz radio is radio 0, and the 5-GHz radio is radio 1.
Step 3
power local
These options are available for the 802.11b, 2.4-GHz radio:
{ 1 | 5 | 20 | 30 | 50 | 100 | maximum }
These options are available for the 5-GHz radio:
{ 5 | 10 | 20 | 40 | maximum }
Set the transmit power for the 802.11b, 2.4-GHz radio or the 5-GHz radio to one of the power levels allowed in your regulatory domain. All settings are in mW.
Note The settings allowed in your regulatory domain might differ from the settings listed here.
Step 4
power local
These options are available for the 802.11g, 2.4-GHz radio:
power local cck settings:
{ 1 | 5 | 10 | 20 | 30 | 50 | 100 | maximum }
power local ofdm settings:
{ 1 | 5 | 10 | 20 | 30 | maximum }
Set the transmit power for the 802.11g, 2.4-GHz radio to one of the power levels allowed in your regulatory domain. All settings are in mW.
On the 2.4-GHz, 802.11g radio, you can set Orthogonal Frequency Division Multiplexing (OFDM) power levels and Complementary Code Keying (CCK) power levels. CCK modulation is supported by 802.11b and 802.11g devices. OFDM modulation is supported by 802.11g and 802.11a devices.
Note The 802.11g radio transmits at up to 100 mW for the 1, 2, 5.5, and 11Mbps data rates. However, for the 6, 9, 12, 18, 24, 36, 48, and 54Mbps data rates, the maximum transmit power for the 802.11g radio is 30 mW.
Step 5
end
Return to privileged EXEC mode.
Step 6
copy running-config startup-config
(Optional) Save your entries in the configuration file.
Use the no form of the power command to return the power setting to maximum, the default setting.
Limiting the Power Level for Associated Client Devices
You can also limit the power level on client devices that associate to the access point. When a client device associates to the access point, the access point sends the maximum power level setting to the client.
Beginning in privileged EXEC mode, follow these steps to specify a maximum allowed power setting on all client devices that associate to the access point:
Command
Purpose
Step 1
configure terminal
Step 2
Step 3
power client
These options are available for 802.11b, 2.4-GHz clients:
{ 1 | 5 | 20 | 30 | 50 | 100 | maximum}
These options are available for 802.11g, 2.4-GHz clients:
{ 1 | 5 | 10 | 20 | 30 | 50 | 100 | maximum}
These options are available for 5-GHz clients:
Set the maximum power level allowed on client devices that associate to the access point. All settings are in mW.
Step 4
end
Step 5
hi,
I just want to know that whats the by default speed & power of radio interface.
wifi(config-if)# speed ?
  1.0         Allow 1.0 Mb/s rate
  11.0        Allow 11.0 Mb/s rate
  12.0        Allow 12.0 Mb/s rate
  18.0        Allow 18.0 Mb/s rate
  2.0         Allow 2.0 Mb/s rate
  24.0        Allow 24.0 Mb/s rate
  36.0        Allow 36.0 Mb/s rate
  48.0        Allow 48.0 Mb/s rate
  5.5         Allow 5.5 Mb/s rate
  54.0        Allow 54.0 Mb/s rate
  6.0         Allow 6.0 Mb/s rate
  9.0         Allow 9.0 Mb/s rate
  basic-1.0   Require 1.0 Mb/s rate
  basic-11.0  Require 11.0 Mb/s rate
  basic-12.0  Require 12.0 Mb/s rate
  basic-18.0  Require 18.0 Mb/s rate
  basic-2.0   Require 2.0 Mb/s rate
  basic-24.0  Require 24.0 Mb/s rate
  basic-36.0  Require 36.0 Mb/s rate
  basic-48.0  Require 48.0 Mb/s rate
  basic-5.5   Require 5.5 Mb/s rate
  basic-54.0  Require 54.0 Mb/s rate
  basic-6.0   Require 6.0 Mb/s rate
  basic-9.0   Require 9.0 Mb/s rate
  default     Set default rates
  ofdm        How to place OFDM rates in rates elements
  only-ofdm   Set rates for best OFDM throughput (no ERP protection will be
              used)
  range       Set rates for best range
  throughput  Set rates for best throughput (includes non-OFDM rates and may
              cause ERP protection to be used)
wifi(config-if)#power local ?
  <-1 - 14>  One of: -1 2 5 8 11 14
  cck        Set power for CCK rates
  maximum    Set power to allowed maximum
  ofdm       Set power for OFDM rates
Scott Fella
Post your show run-config.
If you never changed the tx power or the data rates, then it should be at default which will give you the max coverage for that AP. For 2.4ghz the default mandatory basic rates are:
1,2,5.5,11
All the rest are just entered to be available
Here is a link
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap6-radio.html#wp1232120
-Scott
can i configure this ap with 5 ghz ?
Yes as long as you have a 5ghz radio. 5ghz doesn't go as far as the 2.4ghz, so that will not help with extending coverage.
-Scott
Aqeel,
Please remove your post.  Your response is taken out of a marketing document.  We are talking about real-world scenario.  So you need a more realistic cut-and-paste from a technical document.
