10-22-2002 07:00 AM - edited 07-04-2021 11:28 PM
Sorry about the first post...
I just brought up the 350 Aironet and I am sitting about 2 feet away. My signal strength is Fair running about 30%. I walked about 20 feet away and I lost the signal. Can anyone tell me why this could happen? and How do I fix it ?
By the way. I am running the "rugged" version. I do not have any atennas on it, because my Cisco Rep told me I don't need it. Is this true ?
thanks in advance
jg
10-22-2002 07:30 AM
You may not need one two feet away. You probably need one twenty feet away. You should have an antenna, either integral or add-on, because it's radio.
10-22-2002 08:21 AM
I am running some 342 bridges and know you can change the output level on them. You would definitely need an antenna and you should get a lot higher throughput being only 2 feet away. I would think you would be in the 100 percent range at that distance with antennas.
10-22-2002 09:32 AM
Ok I tried to use the custom setting under Optimize Radio Network For:....now the problem is it won't save under the custom, it keeps going back to throughput...Is it running at 100mw ? Where can I see what it's running at ?
jg
10-22-2002 11:42 AM
Look on the AP Radio/Hardware page.
