06-21-2013 10:30 AM - edited 07-04-2021 12:16 AM
Hi all,
Could you please tell me the best practise of passive survey for big warehouse ? What factors we need to concentrate ?
TS.
06-21-2013 03:17 PM
Vijay,
That's very hard to answer in a forum. The best thing I can say is to use the same ap you will be installing. Also make sure you place the ap at the height you want to install them to get the best reading. Some of the basic is of your surveying, -60 to -65 and -25 to -20 for either voice or data. If the ceilings are high like 35+ feet, and your using the newer generation AP's, then I would also look at using the antennas specifically for the AP's. AP's with external connectors like the 2602e and the 3602e is what I would use.
06-25-2013 10:42 PM
Hello Vijay,
Here are links to a whitepapaer and a cisco doc that clearly illustrates site survey best practices. Hope this helps
http://www.nle.com/literature/Airmagnet_BestPractices-for_wireless_site_design.pdf
