Hi Community.
Until now we're using the Site Survey Kit from Caster Tray http://www.castertray.com/surveyor.html. That works great with the old Cisco AP's that uses POE. But the newer AP's uses POE+ as an example the Cisco 3802.
How you guys are doing Site Survey with the Cisco 3802? I'm looking for a Site Survey kit that has enough power to power up the Cisco 3802 for about 8 hours. Can you help me, which Site Survey Kit manufacturer are out there that supports POE+ ?
Thanks for your help and best regards patrick
