Site Survey with an iPaq and ACU 2.22
rfrederic
I want to conduct a Site Survey (AP352 and PCMCIA Card on iPAQ with AC2.22), my goal is to have a data rate of 11 Mbps everywhere.
What is the best on the site survey utility :
- Active or passive mode ?
- On passive mode : what is the minimum acceptable value for signal strength , signal quality and Overall Link quality ?
- On active mode :
- should I choose None Data retries or Default, Unicast or Multicast Tx Type ?
- if I choose 11Mbps on data rate, what is the impact on statistics when test is running and the client could'nt transmit at 11 Mbps ?
- When test is running what is the acceptable value for Lost to Targ, Lost to Src, % Retries and Percent Success ?
Well, thanks for your reply.
I saw this URL, but it describe how to use the site survey utility and I wonder what is the relevant statistics obtain with this utility and how to use this stat.
Another question : do you know how to obtain statistics display as dbm under windows CE 3.0.
